DPF warning light
Old Dec 7, 2016 | 05:26 PM
Dave Witts's Avatar
Default DPF warning light
Hi I have a 2007 A4 TDI 170, on Sunday I did a forced regen and got the Particle Filter Load Coefficient down to 11%. Since then I have done 73 miles and the dpf light has come on again. I have hooked the car up to VCDS tonight and got the following whilst idling:
Address 01: Engine Labels: 03G-906-018-BRD.clb
Control Module Part Number: 03G 906 018 AQ HW: 03G 906 018 AQ
Component and/or Version: R4 2.0l PPD1.3 G 9971
Software Coding: 0000072
Work Shop Code: WSC 01245 210 53446
VCID: 74E06BE9144A909E65-517E
1 Fault Found:
000665 - Boost Pressure Regulation
P0299 - 006 - Control Range Not Reached - Intermittent - MIL ON
Readiness: N/A
19:16:40 Group 067: Particle Filter (Exhaust Gas I)
147.7°C Temperature bef. Turbo Charger
115.7°C Temperature in Particle Filter
12.6 mbar Press. Difference Particle Filter
0 mbar Press. Difference Offset
19:16:40 Group 075: Particle Filter (Exhaust Gas IV)
123.9°C Temperature bef. Particle Filter
54.1 % Particle Filter Load Coefficient
84.7°C Temperature after Particle Filter
19:16:40 Group 068: Particle Filter (Exhaust Gas II)
0.72 Particle Filter Carbon Mass
0.0 % Carbon Mass Learned Value
Can anyone advise as to why the dpf light has come back on so soon and possibly suggest any cause for this?
Many Thanks
Trickstar
Aug 8, 2013 12:10 PM
Sarah Mansoor
Jan 11, 2012 01:44 PM
PSW
Jun 2, 2008 05:36 PM
