:: ECS Tuning :: B7 A4 P3 Cars Vent Integrated Digital Interface
Countdown to launch. All systems go. Engage.
Before your next stop light liftoff, add a space age digital system monitor to your cockpit. P3Cars Vent Integrated Digital Interface is a plug-and-play data display that "fits like factory" into the left side dash vent, in easy view of the pilot seat.
Pop it in and plug it into your car's onboard diagnostic connector. Then scroll through critical vehicle parameters and monitor manifold pressure, system temperatures, and other vital stats.
No programming, coding, cutting, or splicing
Key Features:
- Fully Reversible Installation: Simply plug into your OBD-II port and you're functional. No splicing or rewiring required.
- Precise Color Match and OEM Integration: Seamless integration with interior lighting including auto or manual dimming to match dash brightness.
- Advanced Custom Programming: Designed and programmed specifically for each car and engine, so you can be sure all features will function as expected.
- Live Performance and Sensor Data: Real time “as it happens” data display of multiple parameters with virtually no lag or delay.
- Built In Acceleration Performance Timer: Automatic start and stop 0-60mph (0-100kph) timer for evaluating your car’s performance and driving skill.
- Diagnostic Data Interpretation & Reset: Read and clear diagnostic trouble codes (DTC) to reduce trips to the dealership.
- 3x Analog Inputs for High Precision Sensors: Universal 0-5v inputs for adding additional sensors or switching boost to an analog vacuum tap.
- Easiest Installation Possible: Put it in, plug it in, installation for even the most novice do-it-yourselfer. Optionally pre-installed in an OEM vent for further ease of installation.
Engage
Click HERE to order or for more information
Fits:
Audi B7 A4 (2005.5-2008)
Let me know if you have any questions.
Jason
ECS Tuning
Sep 12, 2014 12:05 PM
ECS Tuning
S4
ECS Tuning
Sep 4, 2013 12:46 PM
ECS Tuning
B8 Models
Sep 4, 2013 12:44 PM
ECS Tuning
RS4
Sep 4, 2013 12:36 PM
