fault code question
Old Nov 18, 2010 | 10:11 PM
Phil123's Avatar
Default fault code question
Have a 2006 A4 2L - CVT/FWD.
Engine light came on and the garage said it was 0456 and 000A. Do these mean anything to any of you or where can I find a listing of the codes. They also said that changing the fuel filler cap may solve the problem. Also a can controller. Make sense? What's involved with the camshaft controller?
Any help appreciated.
phil
Old Nov 23, 2010 | 11:37 AM
handyandhandsome's Avatar
Power train diagnostic codes start with a "P". So let's assume that your mechanic just did not use the "P" when advising you of the power train diagnostic codes that he obtained from an OBD II code reader.
The P0456 code = EVAP Emission Control System Leak Very Small. It is possible to obtain this code if your fuel filler cap is defective as noted by your mechanic.
The 000A code...as far as I know, this is not a valid code. Specifically, the "A" is not valid. There are valid codes P0001 through P0009. I would ask your mechanic to verify this code reading.
Old Nov 23, 2010 | 01:12 PM
Car_Girl's Avatar
Fault Code 000A may be an intermittent fault code - signal too low. Google the code and this is the description that comes up. I'm not sure which signal the code is referring to though. Sometimes low signals are due to low battery voltage or corroded signal pins where voltage drop occurs due to resistance increase in the connector interface where corrosion occurs.
Auto Zone, if you have these in your area will do free code checks if the mechanic you went to charges a fee.
liamol
B7 Models
Dec 5, 2011 03:41 PM
cardiffkid
Oct 13, 2008 12:52 PM
JohnnyS4
Oct 13, 2008 10:02 AM
PKSJeter
May 15, 2006 05:18 PM
aznek
Mar 2, 2005 09:35 AM
