Fluids
Old Jan 19, 2010 | 03:33 PM
yimstab7's Avatar
Member
Default Fluids
Can i use autozones or walmarts power steering, brake, and coolant from there?
If so whats the best ones i can use?
If not where can i buy besides the dealership?
Is it okay to use Lucas for all of these?
Thanks in advance for a quick response and for the help. All my levels are right at the low level signs.
Old Jan 19, 2010 | 03:37 PM
yimstab7's Avatar
Member
i forgot to mention its a 2006 audi a4 2.0T FWD CVT transmission. Bone Stock with a lil cosmetic. and also questions about the tranny fluid too.
Thanx
Old Jan 19, 2010 | 03:57 PM
auditech79's Avatar
I wouldn't use anything in walmarts auto department......
The power steering fluid in our cars is a mineral based fluid so its unique in that, so there isn't going cheap there, but the stuff from either VW or audi, they use the same stuff.
The coolant is G12, it isn't interchangeable of any other coolant, regardless of what prestone says, it will gel up on you if you mix it.
Brake fluid is brake fluid, just make sure not to use DOT 5, and read your manual for which DOT is used in your car, i believe its DOT 4.
I buy fluids from www.ecstuning.com for cheaper than the dealer sells it.
Old Jan 19, 2010 | 08:17 PM
yimstab7's Avatar
Member
thanx auditech how would i add rep points for you like they do in audizine?
diablo10
Oct 16, 2009 10:42 PM
diablo10
Oct 16, 2009 10:38 PM
aramkim
Feb 12, 2008 05:06 AM
midohioguy
Oct 22, 2006 04:03 AM
toyolla86
Jun 1, 2006 01:13 AM
