Sorry if this is not the right place, I'm new and don't know where i goes. If someone could help me with a problem, I'd appreciate it.
Just bought a used 2008 A4 2.0 quattro. Did not come with a satillite radio so I found one on line from Europaparts for cheap. from what I read on the web I got an old one with the dual antenna connectors not a single one. My pre wired has only 3 plugs, including the atenna not four. The satellite mopdule has dual antenna outputs which means there are four. From what i read the ones with four are old and the new cars won't recognize it. But Europparts said it would and emailed me instructiuons which involve a 2000 dollar scanning tool and changing CAN BUS connector (???????) They say you have to do this with any module. My question is, if I buy a newer sat module, that is for the newer car and only has three inputs, will it work after I simply plug it in or will I still have to do all this stuff with the scanning tool. I thought I could simply plug it in and activate it. Thanlks |
used audi questions
I am about to buy an 06 Audi a4 2.0t with 60k miles. I am inquiring about possible stuff i should check before buying it. For example, cams and followers?
Thanks!! |
my vehicle, an audi 1.8t multitronic 2005 model, starts to vibrate inside the engine area whenever the speedometer is above 100km.what may be the cause of that and how serious is it?
cant find a thread to post on but i need help got a a4 2.0tdi sline 05 had a map but i have a decat pipe lying in the garage was wondering if it will be any good on it ? or will it ruin it ?
In CVT there are no gears and gear ratio changes when there is a change in structure of two pulleys and it is also known as continuous variable transmission.
Hey holyholley23, did you check the idea of leasing? I personally have leased a car from https://dsrleasing.com/ and I am very satisfied! You will find here amazing deals on many vehicles!
People, I beg you, please, we are in the Audi forum, call it Quattro!!!!! =)
