headlights help
hey guys i have a 2008 audi a4 with factory bi-xenons... i was wondering how can i get these headlights to fit it?!?! because all the headlights i want say (will not fit factory bi-xenon) so someone please help me?!
LED DRL Dual Beam Projector HeadLight AUDI A4 S4 RS B7 | eBay
Do you have access to Vag-Com? I am not sure of the connectors, if they are different (I would imagine they are not...but not sure). BUT I do know you will have to get into Vag-Com and change the system from bi-xenon to halogen. If you don't, you will have codes pop up left and right from dipped lamp to control module codes. Each headlamp has it's own control module/starter which on my car (early b7) is mounted externally from the headlamp housing. I discovered them when I had some headlamp issues earlier. Also get the Bently CD if you don't already...it will help out with dis-assembly. It maybe one of those things you just have to spend a saturday, take apart and investigate a little before you make a purchase. Anyway...if it were me, I would actually do a search for the DIY info on adding those LED strips into your existing headlamps first. I think it would be much cooler to keep your bi-xenons and just add in the LED strips...but that's just IMHO. Good luck with it.
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
