Need Help! 06 A4 won't pass inspection
Old Nov 29, 2015 | 08:56 AM
jjhasmadskillz's Avatar
Default Need Help! 06 A4 won't pass inspection
Recently my wife's 2006 A4 2.0T Quattro had the check engine light come on. Ran the code and it was for P0011. The car ran fine and always has. Light comes on and off sporadically. Sometimes its on for days, then off for days, but always runs fine. Went through inspection last week. The car failed for 2 codes P0011 and P2181. I googled both codes and still not sure what to do. Any help would be great. Timing belt was done 2 years ago just fyi
Old Nov 29, 2015 | 01:53 PM
KingWulfgar's Avatar
P2181 is probably your thermostat. It's possible it could be the coolant temp sensor and that's something you can try first (as it's cheaper and less labor), but most of the time this seems to turn into the t-stat. Does it come up to temp slowly or wander around the gauge? It should come up to midway on the gauge quickly and stick there steadily. If it doesn't, it's another good sign your thermostat is stuck/bad.
No clue on P0011.
Old Nov 29, 2015 | 03:00 PM
It seems like the temp gauge gets around halfway and stays steady, but I've seen it more on the cold side as well. Maybe I'll have the t-stat changed and hope that clears that up
millenia
Dec 23, 2019 11:47 AM
FixOrRepairDaily
Dec 21, 2017 04:17 PM
jjhasmadskillz
B7 Models
Nov 28, 2015 02:34 PM
cmarin
Jan 21, 2010 05:50 PM
Dudek12
Jun 2, 2006 11:07 AM
