Need help.....misfire
Old Apr 19, 2017 | 02:14 PM
Darayvn's Avatar
Default Need help.....misfire
The car had been misfiring. Ran the codes, cyclinder 2&4. Replaced all the plugs and all the coils on all cyclinders just to be safe. Car ran fine for a week. Did the same thing. Started chugging on take off and idle. It's really bad when you get up to 70 on the highway. Checked codes. Cylinder 1 misfire. Now the check engine light is off but it's still running like a misfire. What else could it be?? Any help would be appreciated.
Old Apr 21, 2017 | 12:13 AM
a4a4a6's Avatar
Hi,
did you get any other codes along with the misfire?
Old Apr 22, 2017 | 01:14 PM
Darayvn's Avatar
Nope no other codes. Now I just had a cylinder 3 misfire this time. Not number 1 cylinder. And a shitload of smoke blew out the exhaust when it happened.
Old Apr 22, 2017 | 11:06 PM
a4a4a6's Avatar
I had similar issues with random misfire. It was along with the idle speed high code. I changed the spark plugs and it seems to work. Few months earlier I had changed the relay dealing with the ecm voltage and power. The relay is in the box where the ecm is on the driver side on my B7. It may not be your problem however since you are not getting the voltage code. Not sure what else to say at the moment.
Old Apr 25, 2017 | 09:09 AM
Darayvn's Avatar
Now that I think about it when it first happened it had a code that was like timing advanced??? Something like that. But when it was cleared out it has not come back since. I've been monitoring the timing with the veepeak odb wifi link. I don't know where it's supposed to be but it fluctuates up and down. It's color coded and has never gone in the red range. Assuming the red area is bad.
Old Apr 25, 2017 | 09:16 AM
a4a4a6's Avatar
I think I spoke too soon. My car misfired yesterday big time. Left it alone and went to work. Came back and the car will not even start now. Cleared codes (random misfire) but no start. So I guess I am back to square one on this.
I will let you know as I go if I manage to get it fixed. If you come across an idea please let me know. I think I will start with ignition coils first but the coils should not kill the entire engine unless they all go at the same time, unlikely. The next one is vacuum leak. I had a problem with the vauum pump and also have a noisy tensioner, some oil leak from the back where the vacuum pump is.
So lots of things to do and check. It is surprising that it was working OK jusat with the spark plugs for some time and then dead:-)
Old Apr 25, 2017 | 11:29 AM
KingWulfgar's Avatar
Usually, they throw other codes, but check your fuel pumps. Sounds like it was intermediately not getting the needed fuel and now no fuel at all.
Old Apr 25, 2017 | 11:03 PM
Darayvn's Avatar
So your saying that there would be other codes other than just a cylinder misfire code?
Old Apr 26, 2017 | 12:32 AM
a4a4a6's Avatar
Thanks for your comments.
I checked the fuel line and it is delivering fuel to the HPFP. I can also hear the in tank pump priming. Haven't checked the HPFP yet.
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
JETSPEED333
Apr 23, 2011 01:16 AM
JohnnyBravoA4
Jan 10, 2007 02:58 PM
