New Audi Owner
Old Dec 30, 2013 | 11:08 AM
applethunder's Avatar
Default New Audi Owner
Hi Guys,
I am new Audi owner just thought I would say hello.
I have an Audi 2.0 2007 S-line car. The car has 125K on the clock. I would like some help/advice.
1. Should I use the original Audi coolant and engine oil? If yes, where is the cheapest place to purchase these items.
2. I have an engine management light on at the moment. The fault says - boost pressure regulation control range not reached P0299.
The car seems to be running fine but I want to get this problem sorted. Any help or advice would be much appreciated.
Thanks,
Applethunder
Old Dec 31, 2013 | 05:11 PM
KingWulfgar's Avatar
There's an Audi/VW spec for oil. I don't change my own, so I'm not 100% sure of it, but you should be able to find it with some searching. I would also stick with whatever the manual recommends for coolant. Just not worth cutting corners in those two areas.
It's possible you have a failed Diverter Valve. Won't cause any problems to drive it like that, but you're leaking your boost out and affecting performance. See the sticky thread at the top of the forum for more, but the newest revision OEM part runs about $80 and is not prone to the same failure. Hopefully, it's the simple fix for that one.
keunsar
Jan 19, 2015 08:58 AM
Fox Lee
Feb 20, 2013 07:40 PM
AudiBusaMarv
Nov 29, 2010 03:51 PM
Its the wifes car...really
Apr 11, 2009 01:23 PM
cool_kyle_3000
Oct 4, 2006 04:46 PM
