New brake pads and rotors @ 29K?
Old Feb 4, 2010 | 11:37 PM
  #21
2wdBlazer's Avatar
c-clamp wont just work. You have to squeeze and turn at the same time. Not just squeeze.
Old Feb 14, 2010 | 09:50 AM
  #22
phosphateb's Avatar
guys when get my brakes done will post the price...probably in the next 6-12 months will have em done all around..if necessary.
Old Mar 8, 2010 | 01:49 PM
  #23
n_gunjan's Avatar
Default Audi A4 2004 55 K service+ rear Brake Pad + Rotor
Hello Folks,
I have Audi A4 204 1.8T.
The Seattle Audi dealer is charging me a total of 905 + Tax for following:
1) 55k Service : 350 + tax
2) Rear Brake Pad +Rotor: 475 + tax
3) Brake fluid flush : 80 + tax
Is it a rip off or a fair price ? comparing only between Audi dealerships and not independent mechanics or self service.
Any feedback is appreciated.
Thanks!
Old Mar 8, 2010 | 03:01 PM
  #24
2wdBlazer's Avatar
Ask the B6 forum.
1. Depends on what is included in your service. I had bought the Audi Care Plan up through 65k of services including all oil changes and everything. Works out to the customers favor.
2. Way Expensive. I had cut a nice sized groove in my rear rotor from my pad getting too low but it was still straight and no vibration so I put on some $25 Advance Auto Parts Pads on my B6 and I was good to go. Why would you even need rotors especially on the rear?
3. I guess thats ok if you don't wanna fool with it.
I would take the job to an independant Euro Mechanic. There is usually one or more in all major cities who will just as good a job than the dealer. Get the brake tool and do the rears yourself.
Old Mar 8, 2010 | 03:56 PM
  #25
n_gunjan's Avatar
Thanks..Kris..here is what's included in 55Ks service.
-Change the oil and replace the filter
-Check the washer and top off if necessary
-Check for wear and damage of tires and check pressure
-Reset service reminder display
-Check the brake system for damage and leaks. Check the pad thickness and fluid level
-Check the cooling system level and top off if necessary
-Check the exhaust system for damage and leaks
-Perform an on board engine diagnostics-check for any fault memory stored
-Check the engine compartment for any leaks
-Check the electrolyte level of the batter and add any fluid if necessary
-Replace the dust and pollen filter
-Check the transmission for any leaks
-Clean the sunroof guide rails and lubricate rails
-Check the dust seals on ball joints and tie rod ends of the front axle
-Check all exterior lights and adjust headlights if necessary
-Check the drive shaft boots
-Lubricate the door hinges and check straps
Old Mar 8, 2010 | 09:55 PM
  #26
2wdBlazer's Avatar
So basically $350 for an oil change and stuff you can check yourself. I think i'd pass on that.
sbaer2
Mar 5, 2013 11:06 AM
ss5489
Nov 14, 2011 12:52 AM
Kealoha3
May 20, 2010 04:43 PM
QuattroSD
Nov 6, 2007 04:50 PM
ebang
Aug 12, 2004 11:59 AM
