New!!! ECS 2.0T FSI Silicone Upper PCV Hose Upgrade
Replace your heat hardened PCV Breather Hose with the better flowing and more durable Silicone PCV Breather Hose on your vehicle for fewer headaches under the hood!
Click HERE for your Audi 2.0T FSI Silicone Upper PCV Hose Upgrade
If your VW or Audi is suffering from a cracked or brittle PCV Breather hose, or you just hate to mess with the factory clip-on style fittings, the ECS Silicone PCV Breather Hose is just for you!
This hose is molded to OEM specifications and is a direct replacement to the failure prone and heat hardened breather that is universally disliked.
Our silicone hose is capable of withstanding much greater temperatures and is inherently more flexible in its design, with the added benefits of improved airflow and less turbulence!Update your PCV Breather hose today!
Click HERE for your Audi B7 A4 2.0T FSI Silicone Upper PCV Hose Kit
Click HERE for your Audi MK2 TT 2.0T FSI Hose Replacement Upgrade
Click HERE for your Audi 8p A3 2.0T FSI PCV Hose Repair
^negitve on C7 fitment at this time
[IMG]https://c1552172.ssl.cf0.rackcdn.com/1006994_x800.jpg[IMG/]
ECS 2.0T FSI Silicone PCV Hoses
