Is this normal
Old Feb 10, 2009 | 05:15 PM
skiffangler's Avatar
Default Is this normal
I have a a4 6 speed and if I have the clutch in and put the shifter into gear it sometimes goes in roughly(this is occouring before I engage the clutch just moving the shifter). Also after I have the clutch down and it occurs, it shifts smoothly if I still have the clutch down but if I lift the clutch up and push it back down it reoccurs on the first shift. It occurs worst in 1st and third gear and reverse.
thanks
let me know
Old Feb 10, 2009 | 09:07 PM
rams456's Avatar
i also have a 6 speed, and yes, especially when the car is first warming up the gears are pretty rough
after about 5 minutes of driving, the gears get smoother
Old Feb 10, 2009 | 09:33 PM
dmfan016's Avatar
reverse is not a sychronized gear so if ur having trouble getting it into reverse....let down the E brake and let the car roll either forward or backward ......nothing crazy ya kno just a little bit like a few inches or so it should go into gear totally fine
1st gear is rough when the car is cold, also downshifting from any gear to first (even if the clutch is depressed all the way and stays that way until you reach a complete stop) it is near impossible to shift into 1st because there is a protection mechanism that won't let you until your under 10 mph
3rd gear idk tho..its never given me an issue
Old Feb 10, 2009 | 09:36 PM
hcaudikeed's Avatar
i saw a guy on here mention that the 2nd-3rd shift was rough on his car. believe it was sourdiesels4.
Old Feb 11, 2009 | 07:11 AM
It sounds like its just how the cars are but Ill just keep driving and then if it gets worse bring it in for warranty.
Thanks
Old Feb 11, 2009 | 08:20 AM
Oafy22's Avatar
I'v never had any problem with my gearbox. Besides the cold, I don't think Iv ever had any gear catch. If its grinding at all be sure to take it in. How many miles are on the clutch? Normally reverse is the first to catch as your clutch goes. Third is unusual...
Old Feb 11, 2009 | 09:47 AM
its not my actual gears, this is before I actually engage the gear by releasing the clutch. Its the actual shifter moving it with the clutch all the way engaged, it feels rough sometimes.
Old Feb 11, 2009 | 11:33 AM
dmfan016's Avatar
yea...actually moving the shifter into the gear....its tough right?
Old Feb 11, 2009 | 01:51 PM
yea its moving the actual shifter into the gear position
Old Feb 11, 2009 | 09:14 PM
dmfan016's Avatar
yeah thats what i was tlakin about sorry if i confused you but my car does the same thing....but only in cold weather or when the car is cold
Nevalite
Apr 23, 2010 11:39 PM
sirminder
Aug 13, 2009 11:08 PM
P.O.S._for_today
Jun 4, 2009 07:21 PM
Bklynrx7
Apr 21, 2009 12:55 PM
Brandon2000s4
Jul 20, 2007 06:44 PM
