Odd stalling issue A4 2.0
Old Jul 13, 2010 | 07:20 AM
helm2lee's Avatar
Angry Odd stalling issue A4 2.0
Hi, all,,, I am new to this site, have two Audi's (04 A4 1.8T 6spd & 05 A4 2.0T 6spd Avant). I am a marine mechanic (diesel-electrical & electronics) don't claim to be an auto mechanic but am stumped on a weird problem.
My wifes 05 2.0 Avant stalls only on restart, after its been warmed up, and only once. You crank the engine it seems like its starving for fuel then starts and then the problen goes away. It doesn't stall while driving ( although there is a very slight hesitation issue when accelerating), only after restarting once, and only when warm. Initialy there was no DTC (codes) I took it to a local shop and got codes P0089 Intake manifold Runner position sensor switch and P0089 Fuel Pressure Regulator performance. But they are not sure that is the real issue. I am wondering if this is a vacuum problem throwing false codes.
I am purchasing a VAG pro PC program, but wont have it for a few weeks, has anyone come across this issue?
Old Jul 13, 2010 | 11:35 AM
makav3li's Avatar
Anything that has to do with fuel pressure screams a cam follower fail. Your cam follower is located right under your fuel pump which follows your cam. Theres a good DIY here
http://www.audizine.com/forum/showth...IY-in-PDF-form
Its not very hard to check it out, but if your cam has worn through your follower, your lookin at replacing the cam, follower and fuel pump. They are a known failure on these b7's and some have failed as early as 30k miles. I just replaced mine at 50k miles and i could deff see some wear in it. The follower itself is a pretty cheap part, bout 50k. I'd say check the follower and start with that.
Old Jul 23, 2010 | 12:34 PM
helm2lee's Avatar
Default update
I have since received my vag-com and this is what I got.
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: wtf its an audi Mileage: 157630km/97946miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 B HW: 8E0 907 115 C
Component: 2.0l R4/4V TFSI 0120
Revision: --H02--- Serial number:
Coding: 010C010A180F0120
Shop #: WSC 40901 444 59236
VCID: 204508198AAB
8 Faults Found:
012357 - Fuel Pump: Electronics Defective
P3045 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Mileage: 154240 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 63.0°C
Absolute Pres.: 970.0 mbar
Voltage: 12.573 V
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Mileage: 154346 km
Time Indication: 0
Freeze Frame:
RPM: 909 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 62.0°C
Voltage: 13.716 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 2
Mileage: 156532 km
Time Indication: 0
Freeze Frame:
RPM: 827 /min
Load: 16.9 %
Speed: 13.0 km/h
Temperature: 91.0°C
Temperature: 63.0°C
Voltage: 13.335 V
004506 - Fuel Pressure Sensor (G247): Malfunction
P119A - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 5
Mileage: 156577 km
Time Indication: 0
Freeze Frame:
RPM: 827 /min
Load: 15.7 %
Speed: 27.0 km/h
Temperature: 83.0°C
Temperature: 47.0°C
Voltage: 13.843 V
005634 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
001287 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 157442 km
Time Indication: 0
Freeze Frame:
RPM: 914 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 32.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
004688 - Fuel Level too Low
P1250 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 157442 km
Time Indication: 0
Freeze Frame:
RPM: 834 /min
Load: 23.9 %
Speed: 5.0 km/h
Temperature: 69.0°C
Temperature: 32.0°C
Voltage: 14.097 V
008825 - Leak in Air Intake System
P2279 - 002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 157541 km
Time Indication: 0
Freeze Frame:
RPM: 814 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 40.0°C
Voltage: 13.589 V
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004526
Shop #: WSC 06325 000 00000
VCID: 27571305EF85
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 26
Time Indication: 0
End ---------------------------------------------------------------------
It looks to me there are two if not three issues along with the battery voltage possibly throw false codes, in looking at all the dtc's secveral point to the crankcase ventilation valve and or vacum leak I am going to replace the battery since twice at static I have register below 12.5 vdc ( even though it cranks the engine normally and with ever a problem) then the cam follower but i am also concerned this is a cam sensor and or maf issue on thing at a time. I see many people have this proplem on other audi forms as well if anyone has any suggestions or similar experience with this problem please feel free to elaborate. A new symptom has cropped up, when shifting gears the rpms do not drop they actually increase slightly,, this seems to be a alltogether seperate issue.
Old Jul 23, 2010 | 03:10 PM
Audi Dan's Avatar
My B7 had a bad cam follower and I had the same issues when it would shift (revs going up). Here is what was happening. When I'd accelerate hard, like merging into Rte 95 traffic outside of Boston (has to be seen to be believed) things would go fine for about 5 seconds, then the fuel pressure would bleed down because the follower wasn't making a full stroke on the hi-pressure pump. The ECM would sense low pressure, kick the transmission into a lower gear (trying to continue acceleration) and the revs would go back up. I swore I had a transmission problem, but the cam follower job did the trick.
nikpatel
S8
Jan 22, 2015 01:09 PM
Soley4pres
Jul 7, 2011 01:06 AM
amanda west
Feb 9, 2011 09:24 PM
Myst420
Jan 18, 2011 09:15 AM
jwellyman
May 21, 2007 07:28 PM
