P0301, worth just doing coil packs/plugs?
Old Mar 16, 2014 | 07:37 PM
rdlmitedu's Avatar
Default P0301, worth just doing coil packs/plugs?
Hi, my A4 2.0T B7 2006 just hit 121k miles and is due for an oil change anyway. Last night, while accelerating hard, the MIL started flashing for about 5 seconds, then went solid. I pulled over and ran Movi Pro and saw Error P0301: Cylinder 1 misfire.
I was wondering if I should just buy a set of coil packs and spark plugs online and do the replacement myself (I've never done this before, and don't really have a place to do it, but it doesn't sound too hard), or if I should buy the parts online and take them to my local independent shop, or just take it to the independent shop. I like the work the indy shop does, but they had really expensive coil packs when it got replaced under recall about 50k miles ago, so I'm not sure what their normal prices would be. It looks like $120 to buy them online.
Seems to be running fine.
Old Mar 17, 2014 | 04:50 AM
bubbarivi's Avatar
you can change them all in about 10-15 minutes. super easy. 2 screws to release the wire loom. unplug each coil and pull down. pull each coil up and swap plugs and reassemble.
Audi6241
Jan 21, 2016 07:04 PM
jdahlen24
Nov 9, 2010 02:25 PM
drft1
Jul 5, 2010 12:19 PM
drifter22
Apr 19, 2009 08:30 PM
pat7755
Dec 11, 2007 08:11 PM
