Pink Fluid under front of car
Old Jul 21, 2013 | 04:45 PM
kingman's Avatar
Default Pink Fluid under front of car
2005 A4 3.0 Convertible. 105,000 miles
Hi
A
Yesterday l drove approx 8 miles round trip and when l parked in my garage and shut off the
engine l noticed a pink liquid coming from under the front of my car but stopped after a couple of minutes. It was watery with a pink tone. My guess is it is anti freeze. I popped the hood after waiting a couple of hours and noticed the coolant reservoir was almost empty.
I recently brought it to an Audi dealership that is 30 minutes at best away to change the oil.
Because l just moved to Ga. and this was my first visit they gave the car a once over and reported it was in excellent condition and was maintained properly. My guess is that something
Was not tightened enough but only a guess.
I plan on driving it approx 10 miles to a local shop or should l have it towed?
Thanks
Alan
Old Jul 21, 2013 | 07:27 PM
kingman's Avatar
Hi
51 views and no comments?
Old Jul 21, 2013 | 08:15 PM
Nebuchadnezzar's Avatar
Your assumption of it being coolant is correct. If it's at the front of the car most likely the thermostat housing cracked, your water pump is failing completely, or a coolant hose is leaking.
I would advise you of not driving your car 10 miles without coolant. It will certainly overheat and cause severe damage.
Old Jul 21, 2013 | 11:05 PM
imaudi5000's Avatar
yup, thats coolant. my 2008 a4 has 'g12' type coolant that is pink. I cant tell ya where it may be leaking from but check with the local dealer, they may offer complimentary towing, but i assume its out of warranty so it might not be worth free towing to pay them for service.
Old Jul 22, 2013 | 08:32 AM
kingman's Avatar
Called a local shop and AAA will tow it over. Will let you know the outcome.
Thanks
Old Jul 22, 2013 | 10:21 AM
Damaniac311's Avatar
Sounds like water pump seal popped
Old Jul 22, 2013 | 02:29 PM
kingman's Avatar
Default Water Pump
Hi
At 85,000 miles l had the timing chain done and part of it was a water pump replacement
so l would hate to pay for it twice.
Alan
kingman
B7 Models
Jul 27, 2013 07:04 PM
aeeroN
Jun 9, 2012 11:04 AM
marx187
Dec 20, 2009 02:44 PM
powersmokin
Apr 15, 2008 08:56 AM
DLC1.8T
Mar 1, 2006 03:59 PM
