Refil coolant after timing belt
Old Feb 22, 2012 | 09:40 AM
Ericcg82's Avatar
Default Refil coolant after timing belt
So for those of you who have done this job how did you guys do it? According to the bently manual there is a device audi uses to pressurize the system to fill the coolant, I've added coolant in, ran the car with the heater on HI, turned off car and then pulled the bleeder hose off near the firewall until air stopped escaping, topped off resovoir and then repeat until I could not top up the resovoir...
Old Feb 28, 2012 | 06:44 PM
ImTheDevil's Avatar
That should work fine. I usually just fill the system as much as possible and let the car run. That'll draw the coolant in. Top off as needed. What'll happen is air bubbles will become trapped behind the thermostat and keep it from opening. When the car gets 3/4 of the way up the temp gauge, shut it down. Let it cool and pop the cap, fill as needed and repeat.
Old Feb 29, 2012 | 12:22 PM
Ericcg82's Avatar
Cool, yeah I havent had any problems since so I think its all good under the hood...
Old Feb 29, 2012 | 01:55 PM
rodhotter's Avatar
leaving the system open,without cap is recommended to remove air when filling, hope you used distilled water too
Old Mar 1, 2012 | 12:19 PM
Ericcg82's Avatar
G12 and Distilled, not my first BBQ
damoser
Jun 10, 2014 10:54 AM
3dviz
Jan 26, 2010 08:47 AM
benzodiazepine
Sep 18, 2008 02:26 PM
to3o
Dec 19, 2007 01:13 AM
DiscoStu9
May 9, 2007 03:54 PM
