Software required for test-pipe and no check engine light?
Old Oct 16, 2008 | 10:46 PM
a4shorty's Avatar
Default Software required for test-pipe and no check engine light?
When installing a test pipe on the 2.0 A4 B7 will you get a check engine light, or do you need some type of software not to get the check engine light?
Old Oct 18, 2008 | 03:01 AM
Quattros's Avatar
sometimes initially you do not get a check engine light, but rest assure you will get one. Any chip you get will have a file for a test pipe. If you want to avoid getting a check engine light you can go with a high flow cat, which will give you basically the same results and no need to get an ecu flash, although it would optimize the results. PM me if you are interested in a HFC.
Old Oct 22, 2008 | 06:03 PM
mikes07a4's Avatar
I have read on here somewhere that it will throw the check engine light on. I have the pipe myself but I am waiting to put it on until I get the APR tune.
Old Oct 22, 2008 | 06:38 PM
Quattros's Avatar
it will throw a code for sure, no doubt about it
Old Oct 22, 2008 | 10:41 PM
dmfan016's Avatar
theres quite the difference between a high flo cat and no cat at all....
there's no way to that you're not going to throw a code going catless, bosch makes an O2 sensor that fakes the correct O2, and i'm not totally sure if by chipping your car it will turn off a CEL unless you get your car rechipped afterward to fix it....
i'm thinking theres a way to shut it off via the vag-com link but again i'm not sure about that one either
Bernie O' Brien
Audi Q7
Aug 29, 2012 01:39 PM
jsitbon
Jul 4, 2009 10:59 PM
EZAVANT
Apr 6, 2009 12:15 AM
mott6904
Dec 2, 2008 10:32 PM
Dj Spiel
Nov 13, 2007 05:08 PM
