Stage 2
Alright so I have an 07 a4 2.0t quattro and I am planning on going stage 2 with it but I have not done anything yet. I have read many forums about needing a dv when you get an ecu and all that but I really havent heard much as for what exactly i would need to run stage 2. My plan is to get an REVO ecu, and Evo CAI, a revision D stock diverter valve, and an APR exhaust that comes with a downpipe and there is an optional test pipe that goes with it that I plan to get with it. Would that work to run stage 2? Or would i need something else or does anyone have any suggestions?
All you need is the DV, PCV fix, Downpipe or Testpipe. You can do Downpipe / Testpipe only really but the other 2 may blow out at anytime. Ebay has very cheap testpipes and this could save you a ton of cash. When I did my DV it was ripped and I had unknown power loss.
Trust me.
Trust me.
i did the same thing. Revo Stage 2, forge DV w spacer, PCV fix (BSH makes a good one for about $100), 034 motorsport HFC, Stasis exhaust, also you may want to replace the hose on your intake (not the intake box). 034 motorsport makes a good one and helps air get in fast than stock (a little better response), also i have a K&N as well. It sure adds a lot of fun to your car.
Be careful with the test pipe cause it will most likely stink and you may not pass emissions if you get a notice. If you have the money go with a HFC.
enjoy
enjoy
jaybquick
Apr 5, 2007 07:55 PM
