test pipe vs high flow cat
Old Sep 9, 2012 | 10:23 PM
Jebs451's Avatar
Default test pipe vs high flow cat
l.. wuts the diff between high flow cat n test pipe, im looking to get one or the other just need soneone who knos wut theyre talkin bout to help me out
Old Sep 9, 2012 | 10:30 PM
B7Night's Avatar
Be careful with the test pipe. Legally you have to have the cat on the car, or it won't meet emissions. If you live in an area that tests your car's exhaust, you'll flunk, and cause yourself lots of headache. You might also get grief in one way or another selling the car down the road without the cat.
Old Sep 9, 2012 | 10:35 PM
Jebs451's Avatar
ok. but wut the diff. between the two?
Old Sep 9, 2012 | 10:45 PM
Jebs451's Avatar
do u get more horsepower n sound out of a test pipe or a high flow cat?
Old Sep 10, 2012 | 12:11 AM
A4Cragman's Avatar
Cat is restrictive- high flow or not. High flow definitely less restrictive than stock, but its still a wad of stuff in the middle of the exhaust stream no less. Test pipe will definitely be louder and with a lot more cruising drone that might bug you after a while; probably a few extra ponies over the hfc- maybe 10ish at the crank- not a huge difference, but as night said, it'll be a huge pain in the *** if you have smog testing where you live.
Old Sep 10, 2012 | 06:38 AM
Jebs451's Avatar
thanx nice to kno.. does the test pipe throw codes? like will i have to get it flash or anything?
Old Sep 10, 2012 | 10:10 AM
A4Cragman's Avatar
Yes. Post cat o2 sensor won't read remotely correct. Flashing the ecu as far as I know doesn't do anything for that. Only way around it is to monkey with non foulers, which is tedious but effective.
Old Sep 13, 2012 | 08:37 PM
B7Night's Avatar
Also, remember if it's loud enough you may get complaints especially around bedime hours, as well as encounters with the local law enforcement if there are any noise ordinances you might be violating. I know people which have had those things happen.
Old Sep 14, 2012 | 11:49 AM
Jebs451's Avatar
lol ill prolly just get an exhaust then.. but i wan noise but not loud.. just a lil rumble, is there any exhausts that are mellow?
Old Sep 14, 2012 | 01:43 PM
A4Cragman's Avatar
Stasis is pretty low key without a downpipe; the downpipe is where most of the noise comes from when upgrading, bit even with an upgraded dp the stasis setup is pretty mellow til you rip it hard, then it screams in fury lol
