transmission fluid change
yes, it's a sealed tranny with no dipstick. i have no idea how the dealership checks it. nowhere in the owners manual (maintenance booklet) does it show that the fluid should be changed but it does say it should be "checked".
they call it "lifetime" but they really mean during the powertrain warranty. a $500 fluid change every 60k will hopefully prevent tranny problems in the future that could cost thousands.
For what it's worth, I just changed my trans/diff fluid @ 98k. I am aware that this service is overdue relative to other claims on this forum. With that said, when I drained the spent fluid the color was similar to honey, slightly darker, and there was no trace of contaminants, moisture, etc. There was no burnt odor that I could detect. Basically did everything but taste it.
I don't see any reason to do this sooner. However, purchasing 6 qts at ~$17 per qt. (~3.5-3.7qts 75W90 for trans and center diff, they share the same fluid, and ~1.6 MT80W90 at the rear diff [redline fluid]) why not. Only took a couple hours.
