Vacuum Leak help
Hey everybody, I am trying to chase down a vacuum leak somewhere and I'm wondering about the booster near the firewall? It has a little play in it where the 90* elbow mates up with the metal part. It's not much, but it moves in and out and I'm wondering if this could cause a leak? Or is this normal? There isn't all that much oil there that would indicate a leak, although I've read on here they are prone to it. I have some pics of what I'm talking about and am going to try and post them. Thanks.
The vacuum pump is a known problem spot on these engines. Mine was loose and leaky for months and never gave me a code. EVAP leaks are leaks in the evaporative system that traps and burns off fuel vapors--basically one of the many emission control systems in the car. For a small leak, try the N80 valve (also called the EVAP Purge Valve). It's not expensive, easy to get to, and a part that fails. If you
This might hep understand the system:
I replaced the N80 valve. Pretty easy btw. When I checked the code with my torque pro it said I have a pending code p0444. I was able to clear the CEL yesterday after the valve replacement, but today it threw the code p0444. Anyone know where I should check next? It a 2.0 btw.
redmond1501
May 12, 2014 02:55 PM
