Bluetooth Streaming Audio
Yes I am using the original cable given to us by audi that connects directly to the car, and the blue tooth module has a 60 pin port on it. Once in a blue moon the music will skip on me, but overall I'm super pleased with the way it works.
Sorry for going off Topic but
I have a 2006 Audi A6 with multi CD player I would like to exchange the CD player to a USB port so I can play multimedia through the head unit does anyone have any information that would be useful for me as I've tried and lots of Jesus the only option was a radio transmitter plugged into the cigarette lighter which is ok but this is lot of distortion
Thank you for any usefull information
So I guess buying the "hacked" cable from a2dp4audi.com is the cheaper of the two options.
This is great if your hidden menu is enabled...mine apparently is not (holding down the buttons does not bring it up in my 2011 A4), and I don't have the cable / software to enable it.
Trying to use it with the standard ipod cable that came with the car and it says there is no device attached or something.
i am using Bluetooth a2dp adapter from www.sound2air.com they have for 2G MMI and 3G MMI. what you need is just plug it to AMI port and thats it. you can stream music via bluetooth to your
We have the same problem with this AMI, MMI thing to my 2011 A4 Premium Plus. Since I already have this 30-pin iPod connector, my friend recommend this A2DP bluetooth adapter Bovee WMA1000 from viseeousa. From then on, I can stream music wirelessly from my phone library and spotify, and it automatically connects to my phone whenever I enter the car and the good thing is it supports both iPhones and Androids. Its very easy to use just simply plug the device and you can play music and control the steering wheel, etc....
Hey i have a trouble, my steering wheel button for speaer dont work, because i make some mistakes. I also delete the debug.txt file. So now when i connect to bluetooth, my button do nothing. If can help me someone to recode with vcds. Thanks
