Carista app can do Audi coding and VAG-specific diagnostics
Old Mar 20, 2015 | 01:37 PM
Carista's Avatar
Former Sponsor
Default Carista app can do Audi coding and VAG-specific diagnostics
Hi everyone,
Did you know about our app, Carista OBD2? It can do VAG-specific diagnostics and coding/adaptations from the comfort of your smartphone. No cables, no weird interfaces to deal with, no huge expenses. Carista is an app for iOS and Android and it connects to the car through a standard wireless OBD dongle (see: Hardware | Carista OBD2 - Vehicle Diagnostics and Customization )
It's free to run the app and see what customization settings are available for your particular vehicle. If you want to be able to CHANGE customization values or run advanced VAG-specific diagnostics, you need the "Pro Package", which currently costs $19.99 USD and is a one-time in-app purchase that unlocks unlimited customizations and diagnostics on an unlimited number of cars.
We're constantly adding new customizable settings for the Audi A4 B8 and the available ones differ based on the exact year, model, options, market, etc.; that said, here's a sample list of things that Carista can configure for a specific 2013 Audi A4 (UK model):
Doors / Windows / Remote:
Auto-lock doors when moving
YES / NO
Auto-unlock doors when key is taken out of ignition
YES / NO
Auto-lock trunk when moving
YES / NO
Beep when alarm is armed
YES / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Enable settings for opening/closing windows and sunroof
YES / NO
Open/close windows and sunroof via long-press on remote
YES / NO
Close windows via long-press on remote
YES / NO
Open windows via long-press on remote
YES / NO
Close sunroof via long-press on remote
YES / NO
Open sunroof via long-press on remote
YES / NO
Sunroof action when opening via remote
SLIDE / TILT
Open/close only driver's window via remote or key
YES / NO
Open/close windows and sunroof via smart key
YES / NO
Close windows via smart key
YES / NO
Close sunroof via smart key
YES / NO
Open/close windows and sunroof by holding key in door lock
YES / NO
Open windows by holding key in door lock
YES / NO
Open sunroof by holding key in door lock
YES / NO
Close windows by holding key in door lock
YES / NO
Close sunroof by holding key in door lock
YES / NO
Close convertible roof via long-press on remote
YES / NO
Close convertible roof by holding key in door lock
YES / NO
Close convertible roof via smart key
YES / NO
Open convertible roof via long-press on remote
YES / NO
Open convertible roof by holding key in door lock
YES / NO
Blink turn signals when done closing windows via remote
YES / NO
Enable remote control when vehicle is running and in gear
YES / NO
Instruments / Display / Dings:
Display warning about using navigation when moving
YES / NO
Gauge needle sweep at startup
YES / NO
Gauge needles lit even when headlights are off
YES / NO
Gauge scales lit even when headlights are off
YES / NO
Seat belt warning
DISABLED / US/CANADA STYLE / EURO STYLE 1 / EURO STYLE 2 / EURO STYLE 3
Navigation disc eject button
ENABLED / DISABLED
Lights:
Allow configuring daytime running lights via dash display
YES / NO
Use front LED lights as daytime running lights
YES / NO
Use fog lights as daytime running lights
YES / NO
Use high beams as daytime running lights
YES / NO
Use tail lights as daytime running lights
YES / NO
Use side marker lights as daytime running lights
YES / NO
Use low beams as daytime running lights
YES / NO
Dim daytime running lights when ignition and parking lights are both on
YES / NO
Turn off daytime running lights ("wink") when turn signal is on
YES / NO
Coming-home lights
ENABLED / DISABLED
Leaving-home lights
ENABLED / DISABLED
Use fog lights as coming-home lights
YES / NO
Use low beams as coming-home lights
YES / NO
Coming-home lights duration
10 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
Ambient light threshold for leaving-home lights
0 / 1 / 2 / 3 / 4 / 5 / 6 / 7
Turn off front fog lights when high beams are on
YES / NO
Turn off rear fog lights when high beams are on
YES / NO
Flash brake lights in emergency stopping
YES / NO
Flash hazard lights in emergency stopping
YES / NO
Turn on side marker lights with headlights (US models only)
YES / NO
"Euro" parking lights when ignition off, turn signal on
YES / NO
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
YES / NO
Remember position when lowering passenger-side mirror in reverse gear
YES / NO
Auto-enable rear wiper when front wipers on and reverse gear engaged
YES / NO
Old Jan 25, 2016 | 07:47 PM
theoven's Avatar
Can you change the dear display option in this app?
Gear Display option: Enable Gear Display (D1-D6) in
a. [02 – Auto Trans]
b. [Adaptation – 10]
Carista
Jul 7, 2015 11:13 AM
riverr59
B7 Models
Jun 5, 2012 01:25 AM
kiberon
B7 Models
Feb 3, 2009 03:36 AM
inurani
Feb 7, 2005 07:49 PM
