Engine Bonnet won't open
Old Jun 8, 2019 | 06:05 AM
Kevsa's Avatar
Default Engine Bonnet won't open
Hi everyone,
Just needing some advice on how to get my bonnet open on my A4 2009 model.
Checked the release lever under drivers side and cable is attached and tension is there on cable when pulled.
But the bonnet won't pop open.
Anyone any ideas on manually opening it or any advice.
Thanks in advance.
Kevin.
Old Jun 8, 2019 | 07:27 PM
jagtoes's Avatar
Originally Posted by Kevsa
Hi everyone,
Thanks in advance.
Kevin.
Try this but you need 2 people to do it. One persons pulls the bonnet release and at the same time someone in the front hits the center of the bonnet where the latch is. Use the palm of your hand and smack it. If it opens then lubricate the latch and maybe tighten up the cable. If it doesn't you'll most likely need to take it to a dealer. Good luck
Old Jun 9, 2019 | 04:47 AM
Kevsa's Avatar
Much appreciated,
Will give that a go.
Fingers crossed.
Thanks.
Kevin.
Kevsa
Jun 8, 2019 06:18 AM
motocross289
Mar 1, 2011 10:41 PM
cigent117
B7 Models
Nov 27, 2010 09:22 PM
guinness1759
Nov 10, 2007 07:21 AM
flake
Jun 29, 2007 01:34 AM
