Glove Compartment Closed Shut!
Old Nov 26, 2010 | 03:48 PM
cigent117's Avatar
Default Glove Compartment Closed Shut!
Hi all, my B7 A4 has a glove compartment that won't open. The latch seems to be operational and I can pull on it as usual buy it just won't open. Tried prying but it won't work without damaging. Any thoughts on getting it open?
Old Nov 26, 2010 | 05:30 PM
evelluser's Avatar
Not trying to be a smartass, but is it possibly just locked with the key?
Old Nov 26, 2010 | 08:22 PM
cigent117's Avatar
Nope that's not it. Not locked and the latch actually pulls all the way out as usual
Old Nov 26, 2010 | 11:45 PM
evelluser's Avatar
Hmm... I dunno how much overlap there is, but did you try sliding a thin screwdriver or possibly a credit card or similar in there to pop the latch open, while pulling on the handle? Could just be stuck a need a little help like that.
Old Nov 27, 2010 | 09:22 PM
B7Night's Avatar
There is a problem with the glovebox door on the B7. There is a brake that makes the door rise and drop gradually. Sometimes that brake jams. Mine did, and I had to practically slam the door with the latch in the open position to get it to close. Yours might have jammed in the closed positon. There is a TSB about the issue and Audi knows about it. If you are still under warrenty they should fix it.
billymac122
Mar 23, 2012 09:06 PM
Niclipse
Mar 2, 2009 06:01 PM
pliberatos
Jun 4, 2007 02:14 AM
Smailey112
Mar 16, 2007 09:46 PM
moeron7
Jan 30, 2007 11:36 PM
