p0341, p2279, multiple engine misfire codes, low oil pressure warning and car cuts of
I gotta 2010 audi a4 2.0 quattro with man tranny. The physical symptoms is car cuts off at idle sometimes and low pressure warning comes on dash. I also have a few dtc codes. They are p0341(cam sensor), p2279(intake air leak), and 3 engine misfire codes. Car actually runs good except for the cutting off occasionally and im thinking i have a clogged passage somewhere. Maybe cam bridge screen came loose. Will this cause the other problems? what else could it be? Bad crank sensor? am checking the cam bridge tomorrow and going to see if it is broken off or clogged.
