p0341, p2279, multiple engine misfire codes, low oil pressure warning and car cuts of
Old Dec 26, 2023 | 12:51 AM
zedjr10's Avatar
Default p0341, p2279, multiple engine misfire codes, low oil pressure warning and car cuts of
I gotta 2010 audi a4 2.0 quattro with man tranny. The physical symptoms is car cuts off at idle sometimes and low pressure warning comes on dash. I also have a few dtc codes. They are p0341(cam sensor), p2279(intake air leak), and 3 engine misfire codes. Car actually runs good except for the cutting off occasionally and im thinking i have a clogged passage somewhere. Maybe cam bridge screen came loose. Will this cause the other problems? what else could it be? Bad crank sensor? am checking the cam bridge tomorrow and going to see if it is broken off or clogged.
Old Jan 9, 2024 | 06:08 AM
zedjr10's Avatar
Anyone, anyone?
Amazo
B7 Models
Mar 30, 2013 12:40 PM
Cujoca
Jul 23, 2009 06:26 PM
mikowen10
Oct 11, 2007 12:23 PM
2000turbo
Feb 12, 2007 06:33 PM
