Premium Daytime lights
I purchased an Ibiza White 2.0t premium two months ago but I was curious, and want to see what you guys think. I was wondering if i would be able to change the somewhat dim daytime lights bulbs it has now with some h1 bulbs to make them brighter?
I am sure SilverStar, PIAA or Luminics, etc. would have some brighter versions. Just be sure to go with a higher K temp and not a higher wattage which will put out a lot more heat or you may end up melting something...
Is the drl bulbs for premium non xenon is h1 type? I check at the dealer it only says p13w. I also wonder if it just run on 13w not 55w like most h1 bulbs are. Do we need 4 for the pair then? I just replaced my low beam with silverstar ultra, and really satisfied with those. Please any help with those drl bulbs will be appreciated. Thanks
is there a specific size to get though? cause I been searching the Silver Star and they have several types but most are coming up as headlight bulbs, not sure if that would count...can you tell im a newb? haha...appreciate the help tho
