I am considering to update my current 2009 audi a4's headlights from Halogens to LED. Halogens basically suck at night to me and the day time lights are even worse in my opinion. So i did some research and before i made my decision i called my audi dealership and basically asked them if i would be voiding my warranty and I was told to call back tomorrow. Would i be voiding my entire warranty?
So what are the best available options for me to replace my current headlights with some brand new LED ones? I would also like to know if it's just the matter of changing the headlights in order for the new LED headlights to work. I also want to change my Fog lights as well....
Example of what i'm looking for....
I am doing the same conversion right now.
What I have done so far and what I have learned thru searching these forums:
You obviously need new headlight housings.
You will also need:
LED ballasts
Xenon Balasts
Kufatec Wiring Harness
VAG-COM Adapter and PC Software <-- try to find someone who has this because it's $350
The wiring harness has an extra wire that is used to make the high beams work. This will need to be pinned into a harness under the dash.
Then you will need to update the code using the VAG-COM to accept the conversion.
And that's really about it, as I understand it. But I haven't made the conversion yet. Maybe someone else can chime in if I missed something.
You will also need:
LED ballasts
Xenon Balasts
Tech Certified
you better be a coding god to complete this conversion.. you should have just bought the car with the LED headlights.....
the headlights are coded thru many modules.... i have not heard or seen this done....
if you have a link to where someone has done this successfully PLEASE show me
Originally Posted by EthanB5( auditek)
you better be a coding god to complete this conversion.. you should have just bought the car with the LED headlights..... the headlights are coded thru many modules.... i have not heard or seen this done....
It's my decision to do this in the first place and isn't your decision. Second search the thread and you'll find people that have done this already.
Tech Certified
sorry you got so butt hurt, you cant have feelings around here al im saying is i know audis and there will be a lot of coding involved anyways i found one guy who has completed the swap.. he had lots of problems with coding like i said there would be
DIY Halogen to Bixenon- Conversion Complete.
there you go, i dont know what year you have uyou'll need factor long coding for you car to make everything owrk, but good luck, seems like a frustrating job
- Upgrading my B6 halogen headlights to HID headlights - easy or hard?
- Need help with headlights.. New headlights adaptor don't fit
- Is it possible to replace '01 A6 headlights w/new LED headlights?
- Upgrading my projection 'cheap' headlights to Xenon headlights.
