Solar Sunroof relay repair (C5 A6)
Old Jun 5, 2011 | 11:36 AM
phoraris's Avatar
Talking Solar Sunroof relay repair (C5 A6)
Hey guys,
With the weather warming up I was desperate to fix my C5's secondary air pump(I think thats what its called, I havent confirmed with the ross tech but I will soon.). I did a little research on the topic and since the car has some soldering issues I ve decided to take a look inside the relay (385 behind drivers knee panel). Everybody suggested replacing the $$$ relay but it is repairable.
I took the panel screws off and let hang there, popped the the relay (pls correct me if am wrong but when I opened it up it looked like a temperature switch) and open it up.
If you re-soldered you cruise control module you will know what and where to solder.
I re-soldered some pins (4 or 6 of them) that looked bad and put everything together.
Huge smile on my face. Everything worked.
Interior fan circulates air if the interior temperature rises by 10 degrees Celsius. I just wish the dumbass that owned the car before me took care of it and my dash wouldn't need to be glued now.
Sorry I haven't taken any pictures but I assure you it worked on mine. Maybe if someone else tries it can take some pictures on the way.
Hopes this helps. If you have a solar sunroof and your car gets really hot on a sunny day thats most likely the problem.
cms_45
Aug 26, 2021 11:30 AM
misko
Jul 13, 2021 04:11 AM
atebit
Oct 30, 2011 10:43 AM
tariqahmad
Oct 16, 2009 11:49 AM
Willrwilli
Jun 9, 2009 12:48 PM
