1986 5000s?
Old Apr 7, 2006 | 03:27 AM
moosepoop56's Avatar
Default 1986 5000s?
ok i found a 1986 audi 5000s non turbo inline 5 wit 5spd new clutch and AWD and has an exhaust leak for 500 bux...i was wondering if these cars r good cars? r parts hard to find and r they expensive for this model cuz it is misson a couuple mino things like a door handle and couple other small things but i heard it run and it sounded good but i didnt take it for a test run but i was wondering if u guys no anything bout these audi's..and is there a any aftermarket like bolt on turbo kits or is there any swaps from newer audi's u can do to these cars
Old Apr 7, 2006 | 12:29 PM
DojoMax's Avatar
Default RE: 1986 5000s?
ouch
Old Apr 7, 2006 | 05:33 PM
no one knows about these??
Old Apr 7, 2006 | 08:28 PM
0fframp's Avatar
Replacing an exhaust on a 5000 Quattro can be very expen$ive. New door handles can be found and not that expensive if DIY. It is a very common problem with the 4000 and 5000 models. Yea you can find a turbo kit all you need is a 5000 turbo, shouldn’t be all that difficult to find one at a local bone yard.
Old Apr 7, 2006 | 08:34 PM
well im not worried about the exhaust i can do it in shop at school but r the parts expensive and wat other problems r common with these cars
Old Apr 8, 2006 | 12:21 AM
0fframp's Avatar
Overall the Audi 5000/100/200 models hold up very well. As for the problems you can do a search and find plenty of information.
What to look for;
1) cooling/heating/AC system plastic parts tend to leak
2) Central hydraulic system tends to leak at the pump
3) Shocks leak oil if still original
4) Suspension bushing
5) Brake proportioning valve is stuck frozen
6) Power windows don't work
7) Hall sensor in the distributor
8) Fuel tank lining is flaking off and clogging the fuel system
9) Fuel injector seals are leaking air
10 )etc.
Old Apr 8, 2006 | 02:20 AM
DojoMax's Avatar
11) Transmission randomly dying -_- [:@]
Old Apr 9, 2006 | 08:17 AM
BadLuckAudi's Avatar
Those cars are great, ive worked on one for a few years and its a great car, the turbo set up if you pick it up at a junk yard is going to run you around $100 so its not that bad.... but great car over all
Old Apr 14, 2006 | 03:25 AM
thanx for the info
Old Sep 26, 2006 | 11:08 PM
robfresh's Avatar
I was able to find these parts without any problem. This is a great car and you will have minor problems as explain in the comments before mine. The most iritating thing I hated were the door handles even though it only took 20min. to change it out. The exhaust leak can come from around the motor also. These are project cars and once they are running even if it isn't perfect, you will still fall in love with them. Lead Never Follow.
jeffdenn
Oct 13, 2010 07:03 AM
johnnyg
Dec 29, 2009 08:59 PM
johnnyg
Oct 26, 2009 06:53 PM
johnnyg
Oct 13, 2009 07:22 PM
moose127
Jun 11, 2006 12:37 AM
