1988 5000 CS Turbo Quattro Running Problems
RE: 1988 5000 CS Turbo Quattro Running Problems
Glad you solved the problem. While cleaning out the mass airflow sensor did you check to make sure that the sensor plate it is centered and did you clean the plunger on the fuel distributor? This too has a tendency to stick as the fuel gums it up especially if the car sits for a long time. Another frequently overlooked item is the roller bearing located on the arm of the airflow the sensor plate.
