1988 Audi 90 Quattro AGAIN!
Old 12-26-2006, 09:51 PM
neoaudiquattro's Avatar
Default 1988 Audi 90 Quattro AGAIN!
Alrighty Lets get started on why im posting, I was jacking the car up to drain the oil, and waddya know, the car falls off and this pipe cracks, the car runs, but it dies after a minute or so. The pipe that cracked is in the pictures provided. I have no idea what it does, so please let me know!
http://xboxrulez.googlepages.com/brokenhosefar.jpg
http://xboxrulez.googlepages.com/brokenhose.jpg
http://xboxrulez.googlepages.com/brokenhosehand.jpg
Old 12-26-2006, 09:56 PM
Default RE: 1988 Audi 90 Quattro AGAIN!
Use Duct tape and tape it back together.
Old 12-26-2006, 11:46 PM
InExile's Avatar
that is going to case a vacum leak and prevent the car from running ... so in the wort case duct tape
Old 12-27-2006, 12:01 AM
Umm its a 3 way pipe, if i duct tape it, itll collapse and cause no vacuum... What does this do anyway, Because after the car dies the oil light flashes. Does it have anything to do with the oil?
Old 12-27-2006, 01:23 AM
if engine doesnt rotate, what is turning the pump. So if engine stales, no oil preasure.
If you just close that line, like take it away and put something in, your car would run fine. However you will not have vacuem booster. if you put the thing close eniugh, and duct tape a lot, it will not colapse under vacuem.
Old 12-27-2006, 02:24 AM
It starts and runs for a minute, then it stalls. After it stalls, The oil light comes on. But anyway ill ductape it with something to support it. Has this part ever broken on anyone else? Also when the car fell, a jackstand hit the oil pan, the oil pan has a dent in it now but thats what caused the pipe to break, because the engine moved. Theres no hole in the oil pan (thank god) but anywho, Im not going to get rid of this awesome car. So if this doesnt work, ill need a mechanic
SeanMaloney
06-03-2014 04:19 PM
elilundgreen
03-31-2014 01:40 AM
neoaudiquattro
03-15-2007 05:31 AM
neoaudiquattro
02-20-2007 04:06 PM
88ShelbyZ
03-19-2005 09:42 PM
Quick Reply: 1988 Audi 90 Quattro AGAIN!
