1989 Audi 200 10V - Need to find ACC tap for Radio
Old Feb 10, 2017 | 09:51 PM
pdx200_10v's Avatar
Default 1989 Audi 200 10V - Need to find ACC tap for Radio
Can someone familiar with a 1989 Quattro suggest a good location to tap into for ACC that is near the radio?
The 200 doesnt come with 'switched' power for the Radio.
Hoping someone can help out.
Old Feb 16, 2017 | 12:07 PM
pdx200_10v's Avatar
Default Solved
I was able to solve this by using an ACC switched wire off the heated seat switch that sits right above the radio unit. Just tapped into it and works like a charm.
Also use of a multimeter let me use the rear amp to drive the speakers. Crutchfield makes a decent kit that isnt too expensive for a clean fit, but none of the actual pins lined up on my 89 Audi 200 Quattro. I figured out where things connect and the entire aftermaket Kenwood works great.
AND... For those interested, the XM radio SVX300 works fantastic as well with the antenna *inside* the car. You read that right....INSIDE the car sitting right where the front speaker grill is. Its metal ...meaning the magnetic antenna has a clear line of sight to the sky. )
Hope that helps others.
Woofie
Apr 25, 2012 08:49 PM
Mrharrod
Jan 24, 2012 04:09 PM
brianmarie5
Oct 29, 2007 09:07 PM
ScAndal
May 22, 2007 09:31 AM
elvis12
Nov 29, 2006 12:36 AM
