1989 Audi 90
Old May 31, 2007 | 12:41 PM
sdiegidio's Avatar
Default 1989 Audi 90
Hi All,
I have been working on this car for a while. I have had to rebuild the tranny and get the car running. It had not been run in over 2 years so ya, it's been a lot of work. I do not have any manuals for this car. I am in need of knowing what the timing is .. and how to set it on this car plus I need to check the vacuum. If anyone has some help for me here, I would appreciate it. I can not get the timing mark to stay smooth. It keeps moving on me. I am thinking it's a vacuum problem but don't know thebest place to check it and what it should be. Thanks in advance for the help.
Steve
Old May 31, 2007 | 12:59 PM
techbod's Avatar
Default RE: 1989 Audi 90
engine size??
edit: they do a 1.6td / 2.0 / 2.2 / and 2.3
Old May 31, 2007 | 01:30 PM
sdiegidio's Avatar
My bad, hehe. It's a 5 cylinder.. not the quattro
Old May 31, 2007 | 01:44 PM
techbod's Avatar
the 2.0 / 2.2 / 2.3 are all 5 cylinder so ill post both data ( 2.0 and 2.3 are the same but the 2.2 is different, ill download them there are 4 in all and you should be able to tell what the engine is by the pictures
Old May 31, 2007 | 01:45 PM
techbod's Avatar
1 of 2 for the 2.2
[IMG]local://upfiles/12092/B1C74F1B57CE498BBEDD8DC5D3C3F087.jpg[/IMG]
Old May 31, 2007 | 01:46 PM
techbod's Avatar
2 of 2 for the 2.2
[IMG]local://upfiles/12092/38424DF88DC14DF984115FC4EEB47D5A.jpg[/IMG]
Old May 31, 2007 | 01:47 PM
techbod's Avatar
1 of 2 for the 2.0 and 2.3
[IMG]local://upfiles/12092/8A32271D949841AC9AF9349F87D8DE2D.jpg[/IMG]
Old May 31, 2007 | 01:48 PM
techbod's Avatar
2 of 2 for the 2.0 and 2.3
[IMG]local://upfiles/12092/1672CCF765204046B1AECB96BDC9B1DD.jpg[/IMG]
Old May 31, 2007 | 03:05 PM
sdiegidio's Avatar
Thanks Dave,
I have the 2.3 engine. I am guessing the timing mark is the little bump on the flywheel and not a groove like most american cars are. I have put a light on it but the mark jumps around a lot. Do you have any idea what may be doing that?
Steve
Old Jun 1, 2007 | 04:03 AM
techbod's Avatar
idle problem could be the dipstick ( it is sealed with an O ring when inserted ) if its loose when in then there will be air drawn into the engine via that tube and you can buy the O ring,
2.0 and 2.3 are 20 valve engines ans the 2.2 isn't and that's the difference
