1990 Audi 90 Quattro 20V No Spark
Old Dec 5, 2006 | 12:52 AM
ahardy4's Avatar
Default 1990 Audi 90 Quattro 20V No Spark
Hello all I'm new to Audi's and just bought this car. When I went to look at the car a week ago it started and ran good. It then sat for four days and the temperature here got really cold, really fast. I didn't want to drive it around without giving it a good tuneup. Now the Audi won't start, it has no spark and I don't think the rotor is turning. I took the cap off and cranked the engine, when I looked at the rotor it was still in the same position (pointing straight up), does the rotor always stop in this position? Or is it really not turning? I'm also wondering if the rotor just pulls off or if theres a trick to getting it off? I also discovered that the PO filled the coolant system with water which is now frozen solid, I'm hoping this hasn't caused some major problems. Anyways any input is appreciated. Thanks all,
Abram
Old Dec 28, 2006 | 02:33 AM
TommyL's Avatar
Default RE: 1990 Audi 90 Quattro 20V No Spark
ORIGINAL: ahardy4
Abram
For the spark issue, it could be a few things, but go over your connections first, i had a problem with mine. Also an ignition module and wouldnt be bad idea to go over your ignition switch. The rotor has a holder held on by 1 or 2 bolts, cant remember. To remove it, it has gears on the bottom which angle, so just twist and pop her off. It should be easy to come off. As for the frozen water, it should be too bad since water doesnt get any bigger when it freezes, still a pain....
Old Dec 28, 2006 | 02:34 AM
TommyL's Avatar
For your spark, get a test light and start troubleshooting the problem. Thats your best bet to diagnosese the problem, how are your wires and plugs?
Old Dec 28, 2006 | 07:30 AM
techbod's Avatar
if the rotor isn't turning at all either the distributor is bad and the gear is worn or you have a snapped timing belt
johnburke262
Mar 17, 2012 03:45 PM
JmanZ
Aug 14, 2010 11:17 PM
haawill
Feb 8, 2009 01:04 AM
jay54f100
Jun 5, 2007 10:15 AM
PRAGER
Jan 14, 2007 11:58 PM
