1994 Audi 80 Windows Losing Power
Old Jun 3, 2009 | 02:42 PM
ziggy67's Avatar
Default 1994 Audi 80 Windows Losing Power
My front electric windows and sunroof are losing power intermittantly so i seem to have a bad or loose connection somewhere.
Anyone know the most likely cause of this?
There doesn't appear to be a fuse for these under the bonnet.
Old Jun 8, 2009 | 11:25 AM
NH_USA's Avatar
If it were a fuse the power would be off. I would begin checking the ground wires and consctors.
Old Jun 9, 2009 | 06:03 AM
ziggy67's Avatar
Thumbs up
I found out what the root cause was.
If you take off the shelf underneath the steering wheel there is a relay in a black box. I took the circuit board out this black box and checked the solder joints and there was indeed a dry joint. Resoldered the joint, reconnected everything and the windows/sunroof are working perfectly now.
Happy days
If anybody is having a similar problem it is worth having a look at this
Francute87
May 7, 2014 12:14 PM
livesm9
Sep 8, 2013 04:19 PM
kidislegit
Apr 9, 2011 11:02 AM
RANJITANDY
Jul 27, 2005 03:41 PM
