1994 Cabrio 2.8 overheating
Old 06-18-2009, 01:17 AM
kopanaton's Avatar
Default 1994 Cabrio 2.8 overheating
I just purchased this 94 Cabrio 2.8 engine,134k miles.(Is this a Audi 90?).The cooling fans never come on.I checked the fuses for the fans and all were ok.
Is there a sensor that activates the cooling fan and where is it located?Could it be the water pump?Your input will be appreciated.
Old 06-27-2009, 11:33 PM
hubturn's Avatar
Turn on the air conditioning and see if the fans come on. Both should operate. That will test the fans themselves. There are several relays and a temp switch involved in this. The temp switch is at the lower right bottom of the radiator. It has a rubber boot covering the connector. Remove the connector and use a jumper wire to jump from the center to the left and right contact position. The fans should operate. If so, you have a bad temp switch in the radiator. If not, you have a problem in the relays. They are located in the auxillary relay panel under the left dash panel, driver side. Of course, there could be a wiring problem, or corrosion under the contacts on the resistor panel, lower left front, tucked up under the fender. This is a start for you.
frustratingcabrio
06-15-2014 01:04 PM
spongerich
B8 Models
09-24-2013 09:02 PM
Fire4161
02-09-2009 12:46 PM
Fire4161
01-29-2009 06:15 PM
jeffbarry
05-31-2006 09:42 PM
Quick Reply: 1994 Cabrio 2.8 overheating
