4K Quattro Dash Bulbs
Old Mar 17, 2008 | 10:55 AM
alfatodd's Avatar
Default 4K Quattro Dash Bulbs
Hi All!
Has anyone tried replacing the dash bulbs on their 4000 Quattro? Is it difficult? Do I just loosen the screw and then pull the clear plastic off to get to them? They are 1.2 watt, right? Can I use 2 watt bulbs for a brighter effect without melting or overloading anything?
Thanks,
Todd
Annapolis, MD
1986 Audi Quattro 4000cs
Old Mar 18, 2008 | 03:42 PM
NH_USA's Avatar
Default RE: 4K Quattro Dash Bulbs
I copied the following fromChris Miller'sweb site http://members.aol.com/c1j1miller/ giving info about the instrument cluster lights. Your vehicle might be a little different. I did my Audi without disconnecting any wires -once I got it out I just twisted it down and worked on the bulbs. Bulbs can begotten on-line for about$2.00 each.I had an old instrument cluster so all I did was take the bulbs out of it. It was helpful to have a copy of Bently showing where the bulbes were and what they were for.
It is very simple to remove the instrument panel - first two screws under the steering wheel console to remove the top cover above the turn signals, emergency flasher etc.
Then three screws under the lower instrument panel trim piece - right above the steering wheel
There are 4 (i believe) allen screws holding the cluster in place-remove them
Ok the cluster will now move - rotate and slide the cluster to the right and pull out slightly- behind the cluster is a set of wires and connectors attached to the console - no speedo cable
remove the connectors - some have a square tab on top that has to be lifted - some have little plastic arms remove them all. The three dash lights are in with a 1/4 turn and the tape is color coded yellow, black and blue.
Slide the unit out right and pat yourself for using masking tape to prevent wood damage - tight fit.
Now you have the unit out - the bulbs seem to be sourced only at your dealer (maybe a VW part as well) they are Osram 2721 12v 1.2 watt They ain't cheap get a bunch ahead and return what you don't need - that why you pay dealers excessive prices - they expect to provide you service.
All the lights are in with little 1/4 turn pieces - replace what you need -the cluster comes all apart don't fret about removing screws to gain access.
mgriff
May 2, 2008 04:50 PM
macspeed702
Mar 10, 2008 08:40 AM
audi_100
Feb 15, 2006 06:55 AM
KeithW
Dec 10, 2005 05:39 PM
