5000TQ Wagon - Alternator No Good?
Old Jun 24, 2005 | 02:46 PM
Nick86's Avatar
Default 5000TQ Wagon - Alternator No Good?
I have an '86 5000 TQ wagon, and have develloped a charging problem.
While driving the car, it bagan to shut down electrical componants - Radio, guages etc. I got the battery light on the dash, and then the car died. I was able to limp it home, at which point found that the battery was dead. I charged it over night, and now the car starts with no problem. But I am not convinced that there is no alternator issue here. After running the car for a few minutes, the battery will still take a charge from the charger. That tells me the alternator isn't charging..... right?
How can I test to see if the alternator is good or not?
What else could it be?
The PO said that both the Alternator and battery were relatively new, but I have no reason to believe that was the case.
Thanks!
Old Jun 25, 2005 | 12:05 AM
0fframp's Avatar
Default RE: 5000TQ Wagon - Alternator No Good?
Sounds like the brushes are worn down. Remove the alternator and pull the brush/regulator assembly it's one piece and replace it. RockAuto has them for $30. I had a similar problem on my SAAB that also uses a very similar Bosch alternator.
Old Jun 26, 2005 | 04:09 PM
Nick86's Avatar
Thanks for the tip Offramp.
I started the car and put a meter across the alternator, and it was just 12.5V - and falling. So I am confident that the alternator is finished.
I'll see if any of the local parts places sell regulator/brush assemblies. Otherwise I'll visit the local scrap yard.
Old Jun 28, 2005 | 12:23 PM
0fframp's Avatar
The alternator is located in a bad spot without any protection. Yesterday I was driving in some heavy rain and all of a sudden my radar detector started to chirp with low voltage warning. I looked at the voltage gauge and with the engine running it was reading about 10-11V. Either the belt was slipping or the alternator took in too much water. Time to pull my the alternator apart.
feropont
Nov 18, 2009 06:19 PM
irwins41
Jun 3, 2009 08:44 PM
dragonfleye
Aug 20, 2007 06:41 PM
Nick86
Apr 10, 2007 01:30 AM
Nick86
Sep 27, 2005 07:31 PM
