93 Audi 90 cs
I own this type of audi and I do have some questions:
1.Is there a trunk release button?I've read on different forums that in some models,the release is located in the glove box,but not in mine.
2.Some of the sensors on the dash(between speedometer & rpm thing) have been stuck on since I got the car(11/24/08) like: air bag light,antilock light,oil light etc). The oil light flashes on and off at different points of when I'm driving. Is there a way I could fix this?
3 My 'check engine' light comes on when I drive at high speeds for a long time(for example 65 for 20 minutes) but it will click off and then it will come back on again in a little while. Could this problem be part of the sensor?
Any help is appreciated
For the CEL, it could be the O2 sensors. It could be a problem with a cat. or both of them.
I would suggest to unplug the battery for more than 30 min. then plug it back. It will reset the ECU and the codes in the dash.
For the oil light it could be a bad oil pressure sensor or a short(dirty connection).
Please verify your grounds to be clear of all dirt.
