intermittent no start condition
Old May 13, 2008 | 07:03 PM
Yentemad's Avatar
Default intermittent no start condition
Figures that when i finally get all of the right parts installed, my car doesn't want to run right. I took that plastic plug out that i had filling the hole for the idle screw, and installed the right one. Screwed it in until i heard the throttle switch click, then backed it off by about a half a turn. Car starts right up and runs like a champ, a little too high rpm, but was running very well. Shut it off, played with a few things like the isv, the throttle switch, etc and went to start the car again. It fired once but didn't catch and then didnt fire again until i turned the key off and back on again but still didn't catch. Went back out and played with some more things, took the MM hose off, cleaned the gunk off of the butterfly valve, backed the screw off a bit, etc. Tried it again, no luck. Tried one more time, but this time i punched the gas right as it fired and it caught and i held it at about 1500 for a bit and let off. It stumbled around for a bit but eventually started idling beautifully. On a quick test drive it ran amazing as well. Shut it off and went to start again, and its doing it again... I used this as an excuse to get some new spark plugs (NGK bp6et)and it runs a lot smoother, but still has this problem..
Any ideas?
Old May 14, 2008 | 12:44 PM
NH_USA's Avatar
Default RE: intermittent no start condition
Check vacume hoses- especially the ones that are in the starting circuit.
Old May 15, 2008 | 06:48 PM
Yentemad's Avatar
AFAIK, all vacuum hoses are fine. Something interesting i found was that my ISV is running at about 16 amps, when it should have about 500 mA and my frequency valve was running at about 5% average duty cycle when it should be about 40....
Old May 30, 2008 | 10:07 AM
Matt200's Avatar
If you are sure it's not your manifold vacuum, you might try replacing that ISV. It seems to be the problem.
A6Kraut
Nov 5, 2011 11:09 AM
AudiA6_GTI
Dec 27, 2010 02:41 PM
copper07
Nov 3, 2010 08:45 AM
42sport
Jul 17, 2009 09:31 AM
rollinon19s
Sep 21, 2005 02:28 AM
