motor/drivetrain swap
Old May 26, 2007 | 10:34 PM
Motorsport99's Avatar
Default motor/drivetrain swap
Is there any way that an AWD or RWD conversion can be done to an 87 coupe gt? if so what could i use in terms of motors and drive trains? thanks.
Old May 26, 2007 | 10:58 PM
InExile's Avatar
Default RE: motor/drivetrain swap
unless you can custom build a car you can forget about it .... but you could use the same motor that you have and the drivetrain from a 4kq or a 90q .... or better yet find yoursef a 92' coupe
Old May 26, 2007 | 11:03 PM
so you're saying that i can use the same motor but i need new drive train?
Old May 27, 2007 | 12:54 PM
kakarot's Avatar
you can basically use all parts, like from an 90 or same coupe, basically drive shaft and maybe half shafts will be needed to be made custum. engine is swapable, so is the tranny. but I would not recomend converting an FWD into AWD, unless you have the rear end for that car, you can always chop and fit, but thats a lot of work.
if you can get like coupe GT as a donor AWD cheap, that would be nice, then you can make a better car out of them both.
Old May 27, 2007 | 02:02 PM
do they make AWD Coupe GTs?
Old May 27, 2007 | 03:16 PM
kakarot's Avatar
no, they where renamed, Ur-Quatro I belive.
you can get like audi 5000 or 4000 that probably would fit.
you need to check rear welbase to be sure.
Old May 29, 2007 | 08:55 PM
InExile's Avatar
urQ's are $$$ if you can eaven find one , but audi did make quattro coupes 90-95 that were Q 5cyl 20v non turbo ... gust get one of them ... salp aturbo on it and you'll be as happy as can be
Old May 29, 2007 | 08:57 PM
InExile's Avatar
ORIGINAL: Motorsport99
the coupe GT is fwd and you want awd or rwd so yeah a diffirent drivetrain is a must
tallon
Dec 4, 2012 12:13 PM
o0hmikee
Oct 24, 2011 10:19 PM
mlwartman
Mar 1, 2010 10:33 AM
green18
Dec 7, 2007 05:08 AM
tank8970
Nov 28, 2005 11:47 PM
