Oil Scraper Rings
Old 10-05-2006, 07:57 PM
audi90s1994's Avatar
Default Oil Scraper Rings
Hi. On hold with the audi-dealer....Does anyone know the cost of replacing the oil scraper rings?...can a freelance mechanic be able to fix it just as well?
Old 10-06-2006, 12:27 AM
0fframp's Avatar
Default RE: Oil Scraper Rings
It is definitely not rocket science but we are talking a major teardown. Disconnecting everything, taking the engine out, taking the engine apart and then doing the reverse order. Not a DIY project if you are in a rush and have no clue what needs to be done. It took ma about three days with my 4000S and I had all the tools, engine lift, air impact, cylinder hone, ring compressor, bore gauge, etc. The parts will cost a few hundred bucks but if you let someone else do it then it will cost a couple of grand.
Old 10-06-2006, 03:11 PM
okay thanks!
Old 10-06-2006, 03:24 PM
change all the rings not just the scrapers and why not change the big end bearings while your in there, not too expensive if you DIY and not that hard if your mechanically minded, choose to take it to the dealer and you might as well hand the ignition key in and ask them to stick a car on it lol
Old 10-06-2006, 10:53 PM
0fframp's Avatar
I don't think that you can buy the oil scraper rings by themselves. All the rebuilds I ever did, they came in a kit that included all the rings.
Old 10-08-2006, 04:06 PM
why do you need only oil scrapers. get all of them at ones.you can change the rings without taking the block out, only the head, slightly lifting the engine and taking out the oil pan then well, a mecha can take out the pistons replace the rings, and put it back. its easier, but takes almost same time.
when you replace the rings, you replace all of them. couse its dumb replacing each ring each time seperatly.
ECS Tuning
02-04-2015 12:53 PM
dreins
12-31-2011 07:35 PM
skunkoncrunk
11-03-2007 05:37 AM
twenty8red
08-22-2007 11:44 AM
Quick Reply: Oil Scraper Rings
