pitts 84 ur
Old Dec 2, 2009 | 03:54 PM
pitt's Avatar
Smile pitts 84 ur
well ile write this again, did some more work on the q, just what a great classic it is, re alined the rear right hand wheel ,as it was an inch out of true, might of been causeing the car to pull right , havent tested it yet but should be better , fixed the driver side power window as this was not working, found to be the gear drive was frozen as water had seeped in, note the car has been in storage for some time, doesent do cars any good , cars should be driven, the interior is in great shape for the age, dark brown leather , but it smelt like an tomb! found out the water had been getting in as the front inner fenders had rusted through, not terrable , so now they are water tight once more ,it was also hard to get into gear , found out it was the bush on the end of the gear shift control rod, repaird this also, changed all oils except the rear diff as i kneed a shorter hex drive, car has only 80k, its been fitted with the larger europe lights, the cruse device is missing also the injector cooler fan , hate when people take stuff of
just have to figure out why the car is still hard to start, shouldnt be to much i hope, will keep you all posted on what else i find
