Rebuilding 87 5000Q engine.
Old Mar 28, 2014 | 11:26 PM
dave944's Avatar
Default Rebuilding 87 5000Q engine.
Pulled the ol' engine the other day. It's running but has 300K miles on it and it's starting to smoke. Tore it down and it is in surprisingly good shape on the inside. Cylinders look great except the normal buildup of carbon above the ring contact area. Bearing looked great, and no real wear on the crank. Looks like I might be able to get away with an overhaul and a head rebuild. I think the valve seals were the culprit with the smoking.
Anyway, I'm looking around the net for bearings, rings, and seals. What the hell is up with the pricing of the rings? Are they friggin' made of platinum or something. A ring set costs over $100 a piston. I'll blob hone the cylinders and slap the bitch back together before I pay that damn much for a set of rings.
Anybody got any sources that are little more reasonable? Engine is an NF.
Thanks,
Dave
Old Apr 4, 2014 | 12:04 PM
dave944's Avatar
Found some at PartsGeek for under $13 a set. VW number. For Audi NF engine.
1987-1988 Audi 5000 Piston Ring Set - Engine Mechanical - Goetze 87-88 5000 Piston Ring Set - 8623-01023320 - PartsGeek
Now to gather the rest of the bearings, gaskets, and seals. THOSE are not a problem.
Hope this helps somebody out.
Dave
jwhip721
May 19, 2014 01:30 AM
ivancolesnic
Jan 27, 2012 08:58 PM
ivancolesnic
Jan 27, 2012 08:55 PM
marlonduval
Jun 12, 2008 07:51 PM
brianna
Jun 8, 2005 11:49 AM
