Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
AUDI CONCERT BLAUPUNKT
Old Feb 1, 2006 | 03:14 PM
sherpa's Avatar
Default AUDI CONCERT BLAUPUNKT
Hope ive posted this in the right spot!
I've been given an Audi Concert radio cassette made by Blaupunct - it has the code with it but when I connect it up the display shows SAFE and I can't get it to allow me to even enter the code. I don't have any instructions so not sure whats wrong.
Can anyone help please?
Sherpa
Old Feb 1, 2006 | 03:40 PM
techbod's Avatar
Default RE: AUDI CONCERT BLAUPUNKT
without the code its useless ish you can have it decoded but Audi wont touch it because they check it against the Vin number and if they don't match it will be taken from you till its been proved its not stolen
Old Feb 1, 2006 | 04:09 PM
sherpa's Avatar
As I said!!
ORIGINAL: sherpa
Sherpa
Old Feb 1, 2006 | 04:16 PM
techbod's Avatar
ohhh thanks for the large letters im getting on a bit so it does help lol your request is "how to enter the code" ive no idea
Old Apr 9, 2006 | 09:22 PM
lbraasch's Avatar
The following is the procedure to re-activate the radio if the display
shows "SAFE". It is important that the procedure be followed in the
correct order.
Turn on radio. The radio display shows "SAFE".
Press the FM2 and RDS buttons simultaneously and hold until "1000"
shows on the display. Release the buttons. Do NOT press these
buttons again, otherwise the radio will consider "1000" to be
the code.
Use Preset buttons 1 ... 4 to enter the four-digit code number
from your radio card. Preset button 1 corresponds to the first
digit, Preset button 2 corresponds to the second digit, etc.
Each press of the button increments the number by 1.
Once the code shown on the display is correct, press the FM2
and RDS buttons simultaneously and hold until the word "SAFE"
appears in the display, then release the buttons.
The radio should unlock and be usable shortly afterwards.
If an incorrect code is entered, the word "SAFE" appears,
first flashing and then continuously. You can repeat the
above steps to unlock the radio once more, the number of
attempts will be shown in the display. If an incorrect code
is entered again, you radio will be locked for about one hour.
After one hour - the radio must stay on and the key must remain
in the ignition lock - if the display goes out, the you can repeat
the above procedure to unlock again. The cycle - two attempts, one
hour lock-up - still applies.
If you lose your radio code, contact your Audi dealer.
Note: Some European market Concert radios have a TP button instead
of the FM2 button, so the description above with those units would
require pressing the TP and the RDS buttons simultaneously.
Radio Frequency and Reception Quality Information
The following is the procedure on how to access the radio frequency
auto reception quality information display.
Turn off radio.
While pressing and holding the Preset 1 button, turn on radio.
The display shows E D Fxxx where E and D depend on stereo quality of
reception, and where xxx is function of the current frequency. This
is a display-only mode. You cannot change any settings.
When you are done, turn off radio, then turn it back on for normal
operation.
Speed-sensitive Volume Control (GALA) Information
The following is the procedure on how to access the Speed-sensitive
auto-volume compensation display.
Turn off radio.
While pressing and holding the Preset 2 button, turn on radio.
The display shows how many decibels the SVC has increased the volume.
This is a display-only mode. You cannot change any settings.
operation.
CD Changer Detection
The following is the procedure on how to check if the radio detects an
externally mounted CD changer.
Turn off radio.
While pressing and holding the MODE button, turn on radio.
The display shows CONNECT if a CD changer is connected. Otherwise it shows
NO CDC. This is a display-only mode. You cannot change any settings.
When you are done, turn off radio, then turn it back on for normal operation.
Other Preferences & Configurable Options
The following is the procedure on how to access some other preferences that
you may set in the Audi Concert radio.
Turn off radio.
While pressing and holding the FM2 or TP button (whichever is appropriate
for your radio version), turn on radio.
The display will show a parameter that could be adjusted.
Turn the volume control **** to change the setting.
Press the FM2 or TP button to advance to the next adjustable parameter and
you can use the volume **** in the same way. Repeat this until it cycles
back to the first mode.
When you are done, turn off radio, the setting will be remembered the next
time the radio is turned on.
The table below shows a list of parameters that can be adjusted in this manner.
Parameter Description
SVC (or GALA) Speed-sensitive Volume Control (auto-volume compensation) effect
VOL Turn-on volume setting
SENS Station-scan sensitivity (DX/LOcal)
RM Radio Monitoring (whether radio should come on
while cassette is rewinding or fast-forwarding) (OFF/ON)
NAV Navigation system audio mute amount
TA Traffic Announcement volume
The volume of traffic announcements (independent of music volume). This
is applicable to radios with this capability, and operated in an area with such
a service.
(copied from an audi world article)
Old Mar 11, 2011 | 05:35 PM
Ads1405's Avatar
Default Audi concert Radio
Hi, my old chorus radio died in my MY01 A3 and I ordered a new concert from the US. I live is Australia an the AM radio spacings are different. Is there a way to alter this, or a manual available?
Please help!
Old Jul 29, 2011 | 02:19 PM
Kevin A6's Avatar
HEY, THANKS FOR THAT INFO, IS IT NOT NORMAL FOR YOUR RADIO TO BE LOCKED FOR MORE THAN AN HOUR?
BUT I WAS HITTING RDS AND SCAN, SO I WILL TRY THE RDS AND FM2.
where can i buy another AUDI CONCERT radio, the dealers discontinued them...?
[QUOTE=lbraasch;246754]The following is the procedure to re-activate the radio if the display
correct order.
the code.
Old Aug 27, 2012 | 09:23 AM
Markodu76's Avatar
Default Audi concert radio
Hello,
Please I need to code for my Audi concert auz1z3v2719870. Please can you help with the code ?
Many thanks
roke2468
Nov 5, 2009 04:40 AM
Gary
Sep 26, 2007 03:54 PM
SloRide
Jan 2, 2007 03:29 PM
anwa1505
Sep 1, 2006 08:46 AM
