Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Can anyone help with OBD II codes 1198/1199?
Old Jun 16, 2010 | 02:05 PM
caymancop's Avatar
Default Can anyone help with OBD II codes 1198/1199?
my car has just failed inspection on engine management light.... these are apparently manufacturer specific codes.....
help please!
Old Jun 16, 2010 | 04:59 PM
boostin_A4's Avatar
thats easy man check your fuel pump relay fuse it should be fuse 4.
Old Jun 16, 2010 | 05:05 PM
caymancop's Avatar
thanks dude the other one was P0140 which is an O2 sensor, but how do I work out which bank/sensor is which?
Old Jun 22, 2010 | 02:44 AM
Joshua.Madison's Avatar
For most of those look for a vacuum leak. They can often times fool the computer into thinking it needs to add fuel. It also could be a bad air flow sensor. Start buy replacing the bad temp sensor and then look at leaks.
Old Jun 22, 2010 | 02:18 PM
caymancop's Avatar
thanks guys, will replace the O2 sensor then keep looking!
keep the info coming..... please
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
DurTTy
Nov 17, 2007 11:52 AM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
