Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Check Engine Light
Old Nov 13, 2010 | 11:08 AM
pneidermire's Avatar
Default Check Engine Light
My car was idling for about 10 minutes last night in 35 degree weather, when I got in to start driving it the check engine light came on. Any suggestions of what to check on my own before I have to bring it in for diagnostics? I just had a new air filter put in about 1,000 miles ago and the mechanic said everything looked fine.
Much appreciated!
Old Nov 29, 2010 | 07:31 PM
Car_Girl's Avatar
You might have a terrible case of carbon build-up and the only way to verify this is to have your car serviced if you don't know how to pop the manifold cover off yourself.
http://www.audizine.com/forum/showth...ad-for-RS4-4.2
There are a lot of other things it could be too but this is pretty common - you ought to have noticed problems before it got to this point if the issue is carbon build-up.
There also could be water in the fuel, a bad injector or bad fuel pump, bad coil pack, bad spark plugs or bad O2 sensor(s).
Go to Auto Zone and have them pull the code for you and find out what code is set, then post an update and that can help narrow down what to look for.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
