Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Fact or Fiction. Can you recode an ABS module?
Old Sep 18, 2009 | 03:17 AM
vandynamics's Avatar
Default Fact or Fiction. Can you recode an ABS module?
let me get the the nitty gritty.
1998 audi 2.8 a4 avant wagon. the part number of the abs pump was an 8eo 614 111m and im replacing the module with an 8eo 614 111p is it possible to recode this module to work as an M unit? Vag Com will not communicate with the 111m module.
I have vag com, but no bentley manual. Can anyone help or atleast point me in some direction!?
THANKS!
-Cory
Old Sep 18, 2009 | 03:23 AM
this looks like the coding process
All of the following procedures must be performed in order, without shutting off the ignition or exiting out of the ABS controller.
Contents [hide]
1 Login
2 Coding
3 Basic Setting
3.1 Steering Angle Sensor (G85) Calibration
Login
Note #1: After Login has been carried out you need to recode the control module.
Note #2: Special Login 09399 is used for BFB Engine with 1LT Brakes and Multitronic.
Note #3: The PR codes ( such as 1LJ ) can be found in a sticker near the spare tire well. Click this link to see an example of a sticker http://www.ross-tech.net/vag-com/mis...s/PR-Codes.png
0?xxx: Chassis
9 = Audi A4
0x?xx: Brakes
2 = Brembo 17" (PR-1LJ)
3 = FN3 16" (PR-1LT/1LF)
4 = HP2 16" (PR-1LX)
4 = FNR 16" (PR-1LA/1LG)
5 = FN3 15" (PR-1LB/1LE)
6 = C54 (PR-1LZ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
7 = 4/5 Cyl. Gasoline
9 = 6/8 Cyl. Gasoline
0xxx?: Transmission
5 = Manual
7 = Automatic (5HP19, 5HP24, AG4, AG5)
9 = Multitronic (01J, CVT)
Coding
Note #1: Coding is accepted after a specific login has been carried out.
Note #2: After successful coding the steering angle sensor basic setting needs to be carried out.
Note #3: Special Coding 04499 is used for BFB Engine with 1LT Brakes and Multitronic.
Note #4: The PR codes ( such as 1LJ ) can be found in a sticker near the spare tire well. Click this link to see an example of a sticker http://www.ross-tech.net/vag-com/mis...s/PR-Codes.png
0?xxx: Chassis
4 = Audi A4
0x?xx: Brakes
1 = C54 (PR-1LZ)
2 = FN3 15" (PR-1LB/1LE)
3 = HP2 16" (PR-1LX)
3 = FNR 16" (PR-1LG)
4 = FN3 16" (PR-1LT/1LF)
5 = Brembo 17" (PR-1LJ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
0xxx?: Transmission
5 = Manual
Basic Setting
[Select]
[03 - ABS Brakes]
[Fault Codes - 02]
[Done, Go Back]
Turn steering wheel at least 30 ° left and back straight ahead.
[Meas. Blocks - 08]
Group 005 Field 1 (Steering Angle Sensor -G85-)
Specification: 0.0 °
Tolerance (when straight): ±5.0 °
[Done, Go Back]
[Login - 11]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 001
[Go!]
[Done, Go Back]
[Fault Codes - 02]
All fault codes should have disappeared.
[Done, Go Back]
[Close Controller, Go Back - 06]
can anyone verify that using this is what will allow me to adapt the P sensor to an M chassis?
Old Sep 22, 2009 | 12:17 AM
for more information i found these (in respect of information consolidation i will post everything i find out in this thread for others to learn from)
"Re-Activation of ABS control module for Audi S4 (B5 platform)---Only for cars with ESP.
All of this you are doing at your own risk. I am not an Audi mechanic, just sharing what was successful for me.
From VAG-Com, select 03 (ABS Brakes)
Select Login
Enter login code 09495 (6spd) 09497 (tip)
Click "Do It!"
Select Recode
Enter Soft Code 04395 (6spd) 04397 (tip)
Click "Do It!"
Select Basic settings
Select Group 001
Turn the steering wheel +/- 10 degrees and then return to the zero (straight) position. Verify results from the screen.
Clear all DTC codes.
That is all I had to do. For me, the ABS light stayed on for a while until I had driven a round for about a mile. Then it was gone. I went back in and cleared any remaining codes. Try this before the steering calibration.
I have done this on both a Tip (L-box) and 6spd (H-box). The codes are based on ESP, not model year.
Here is the procedure for zeroing the steering wheel. Please do not do it unless you are certain it is needed. I imagine that a DTC code will keep popping up of it. You will keep getting the DTC unless you initiate the sensor by turning the wheel back and forth at least 10 degrees. I did not have to do this with my car, so I am going from the Audi instructions, there may be some difference. I don't have my VAG in front of me while writing this.
Select Login
Enter login code 40168
Click "Do It!"
Select Group 001
There should be an "OK" in a block for Calibrating Steer Sens.
Group 005 should display the zero position.
Switch ignition off
Switch ignition on
Repeat.
Clear any DTC's
Remember...I had to go for a drive (a very slow, safe drive for the light to go out). Come back and clear all the DTC's in the ABS module.
Enjoy (hopefully)."
Old Sep 22, 2009 | 12:35 AM
the Bosch sensor that was corresponding to the 111m brake block was replaced with the sensor from a 111p brake block tonight. Without starting the car (the valve cover is currently off getting seals so starting the car is not an option) there is still a solid ABS light with three beeps and the flashing Brake light. This leads me to make 2 assumptions:
A. Assuming the sensor is in good working order it appears that a recoding is absolutley necessary. Now this could mean i just need to drive around acouple miles to turn the light off, or at worst a complete recode through vag-com.
B. Second assumption is that the "known working module" is in reality a not working module and is suffering from the same problem most modules suffer from; a broken ground on the circuit board of the sensor's internals. After all there is always the risk of purchasing a replacement that suffers from the same problem, especially when there is alot of secondary market trading for these modules online and on ebay.
So i will keep the thread updated through the whole journey of solving my abs problems to hopefully make the repair for others who dont have thousands to spend at the stealership.
Old Jan 26, 2010 | 12:12 PM
roshanjg's Avatar
Default help needed with ABS controller recode after replacement
The ABS controller module was replaced: now the sofware coding is 00000 and Workshop code is 00000. I have the orginial coding (was softwarecoding: 04277, Shop #: WSC 06435 with the old ABS) but do not have the correct login information.
I tried the info given above but it did not work. Can someone help me (how do you generate the correct login?)
Current scan results (2002 Audi A4 Quattro, 1.8L turbo):
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0003
Coding: 0016751
Shop #: WSC 63351
1 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 1213
Coding: 0001012
Shop #: WSC 26118
No fault code found.
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
Address 08: Auto HVAC
Controller: 8E0 820 043 P
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 01141
Shop #: WSC 63351
Address 17: Instruments
Controller: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 03200
Shop #: WSC 85555
WAULC68E32A309611 AUZ6Z0B0093123
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv.
Controller: 8E0 959 433 T
Component: Komfortgerát T5B 0619
Coding: 16232
Shop #: WSC 63351
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
Address 56: Radio
Controller: 8E0 035 195 A
Component: symphony II NP2 0050
Coding: 00201
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
Old Apr 18, 2010 | 03:28 PM
dcsat's Avatar
Select Login
Click "Do It!"
Select Recode
Click "Do It!"
Select Group 001
Select Login
Click "Do It!"
Select Group 001
Switch ignition off
Switch ignition on
Repeat.
Clear any DTC's
Enjoy (hopefully)."
Where did you find this info? I need the login code for an A6 allroad ABS. I would imagine that it is similar to the A4. BUt if the A4 is a "9" what do you supose the A6 will be?
Old Apr 18, 2010 | 03:33 PM
dcsat's Avatar
Default ABS Coding
Hi, this is a great thread, I was hoping someone might be able to help me find the login for an A6 ABS module. I see the login for the A4 is 09497... the first "9" = A4. Any ideas what an A6 would be?
neatyhawker
Jul 21, 2015 10:16 AM
Audi Forums Editor
Aug 7, 2013 07:48 PM
exequiel3k
Jun 6, 2010 10:02 AM
freakaftr8
Apr 5, 2010 09:46 PM
fusionx
Oct 10, 2007 02:10 AM
